Software Defined Networking (SDN)
Best practice on Aruba Controller (7005 or 7008) to use Intervlan routing
We are doing a small SDBranch test on Aruba 7005 controllers and would like to know the best practice on setting up to allow intervlan traffic, or is it better for intervlan traffic to be off completly and then how would I go about adding the necessary rules to allow say print jobs from workstation to printers etc.
As of right now the policy based routing being handed down to all sites does NOT allow intervlan communication, and becuase it's controller managed I cannot go to the specific site and manually add a /22 network for example on what is considered local traffic.
would be interested to hear how others have setup / solved this issue on your setup.
