Software Defined Networking (SDN)
Running Ryu application with Aruba 7024 Mobility Controller
I work at NTU, Singapore. We have developed an SDN application in RYU. Now, I want that application to run with our Aruba 7024 Mobility Controller. I know that HPE Aruba doesn't have option to install the app on it. So, may I know what is the alternative (I heard about REST API)? Kindly mention step-by-step procedure starting from scratch.
MVP Guru
Re: Running Ryu application with Aruba 7024 Mobility Controller
I have not seen RYU integration with the Aruba Mobility Controllers. At least, you cannot install anything on the 7024 mobility controller, like you cannot install anything on most of the switches.
The controller supports OpenFlow in recent firmware versions, but I'm not aware of publicly available applications around that support outside the Aruba Mobility Master that uses OpenFlow with the controllers.
What is the SDN application that you are trying to build? What should it do with the Mobility Controller?
Thanks. We have developed a RYU application for managing end-to-end communication delays in industries. We already have the mentioned Aruba controller. We need to use the developed app for the existing network settings.
