Training, Certification & Career
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Re: ACMP 6.3 exam
Hi ALL.
I am new to Aruba. Kindly could you please guide how to prepare for ACMP exam 6.4/6.3. I have download the Aruba 6.4 USER GUIDE. but wonder if some one have a lab book to practice.
also kindly please advice if it is possible to emulate Aruba OS in vmware, similiar like cisco wireless controller in vmware. or GNS3. all i heard is there is nothing unless we use a reall hardware from Aruba.
sheraz
Highlighted
Occasional Contributor I
Re: ACMP 6.3 exam
Hi Sheraz,
I have attaended a course at the Aruba certified centre in UK. Also, I had the Aruba setuo at work. Hence i did not need to have the setup at home. There are not much aruba books that i could find othe than the courseware.
In my course, we had used real hardware rather than VM. So, i guess you may have invest in some harware. Ebay is a good place to get some.
You have to have in depth knowledge of different product of aruba specially APs and controllers. Also, having a working knowledge of the network will be beneficial for the exam. if you have CCNA, or have read on books, that will help.
Sheikh
Highlighted
Re: ACMP 6.3 exam
Thank you very much for your reply. I am CCIE in routing and switching. I
understand the concepts but only wanted to get my hands on the aruba network
gear. The command line is very similar to Cisco ISO. only problem is to prepare
ACMP exam the Aruba 6.4 User Guide is too much to read. and I am keep
distracting myself. I was thinking to keep the ACMP certification course outline
next to me and keep following it. than it will be easy to prepare for the exam.
please advice what you thing of this idea.
also please advice as i am new to aruba but do understand the wireless
foundations as did work in past on cisco wireless. do i have to do ACMA or it ok
for me to keep on track of ACMP. you valued advice will be much appriciated.
Regards.
Highlighted
Re: ACMP 6.3 exam
In the previous quizbean link, it had a question that said 802.11a can't be used on the 5GHz band.  I'd say this practice exam is bogus.
Highlighted
Re: ACMP 6.3 exam
The question was, "Can an 802.11a device operate in Both 2.4 and 5ghz band".  The answer is false, and that is correct.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Re: ACMP 6.3 exam
I read it too fast, thanks for the correction.
