Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Introduction to AOS-10: Mixed Mode WLAN
When an AP is deployed you have two basic options for routing the user’s data from the SSID. Bridge Mode and Tunnel Mode. However, with the introduction of ArubaOS-10 for the APs and Controllers you now have a blended option that uses the routing and firewall capability built into the AP to determine which clients get bridged locally and which clients get tunneled back to the Gateway.  This feature called Mixed Mode is configurable for the first time on a single SSID
This video introduces how to create a Mixed Mode SSID at AOS-10 devices using Aruba Edge Services Platform (ESP).
Version history
Revision #:
2 of 2
Last update:
‎07-10-2020 08:19 AM
Updated by:
