error is ;
03/26/19 12:01:18 00828 lldp: PVID mismatch on port 1(VID 1)with peer device port 20a6cd-c2432e(VID unknown)(1441)
I 03/26/19 12:01:16 00828 lldp: PVID mismatch on port 3(VID 1)with peer device port 904c81-c781a8(VID unknown)(1441)
This switch is a Aruba 2930F (JL254A) with fireware version WC.16.08.0001
devices connected to ports 1 and 3 are standard access points aruba 305 and 304, managed by a 7205 controller.
I don't know why the port desc. show as bond0
I tried to suppress the error by using "lldp config 1,3 dot1TlvEnable port-vlan-id"
since that didn't work I did "no lldp config 1,3 dot1TlvEnable port-vlan-id"
any help on understanding this would be great thanks.
