2530-24G Switch GUI
I'm new to Aruba, and not real versed in CLI.  A recommendation ended with me purchasing this easily configurable switch which I have been unable to make any changes via the GUI.  It appears the GUI is strictly read only with no modifications allowed.
Is that the case?  Or is there something I need to enable via CLI?
Reviewing # show web-management it does show te HTP access to be enabled.
TIA
Super Contributor I
Re: 2530-24G Switch GUI
I suppose that you are logged in with the operator account and not with the manager account.
With the operator account you have read-only access.
With the web GUI you should be able to make changes
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Thanks for your reply.  In the GUI, I'm logging in as admin.  I assumed that would be an account to make changes but appears it isn't?  I didn't realize there were other accounts.
Super Contributor I
There are two privileges levels, operator (RO) and manager (RW). By default there are also two users, operator and manager, however this can be changed.
See the screenshot below.
In the right corner you can hit the user details button to see which role is assigned.
I'm logged in with the manager account and I can also add new VLANs
MVP Expert
It's important to note that GUI doesn't cover the full spectrum of features you can manage through CLI...it offers you (Manager) just a basic subset with a limited amount of options...that's just to say that if you want to fully govern and understand your Switch you need to get used to CLI....sooner or later.
