Wired Intelligent Edge
2930F number of MSTIs
  • 1.  2930F number of MSTIs
    Posted Apr 05, 2019 06:21 PM
    Hello community,
    I have two 2930F with OS Version 16.05.011 in an VSF stack and want to configure MSTP.
    In the Aruba 2930F / 2930M Advanced Traffic Management Guide for Version 16.05 on page 96 is this advice "When the Switch is configured in a stack, the number of configurable MSTIs is limited to four."
    I can't find this advice in the same Guide for version 16.06. I also can't find any information about this limitation in the change log for version 16.06.
    So my question is:is it officially supported to configure 15 MSTIs on Aruba 2930F in an VSF stack? If yes, on which OS version?
    regards
    pyrmonte
  • 2.  RE: 2930F number of MSTIs
    Posted Apr 08, 2019 04:59 PM
    Here is output from a 2930 running 16.08:
    switch1# show spanning-tree instance
    ist Show the information for the internal spanning tree (IST)
    instance.
    <1-16> Spanning tree instance ID for which to show the information.
    You can configure up to 16 MST instances.
    Justin
  • 3.  RE: 2930F number of MSTIs
    Posted Apr 09, 2019 07:55 AM
    Hello Justin,
    is the switch where you executed the commmand running in a vsf stack?
    regards
    pyrmonte
  • 4.  RE: 2930F number of MSTIs
    Posted Apr 09, 2019 09:03 AM
    This is the information form the Aruba 2930F / 2930M Advanced Traffic
    Management Guide for Version 16.05 on page 96.
    However, when the Switch is configured as a standalone, a maximum of 16 MSTIs is supported.
    I can't find this information in the guides for newer ArubaOS versions. But the changelogs for the newer ArubaOS versions don't contain any information about this.
    Can anybody confirm that the limitation of 4 MSTIs for stacks officially does no longer exist in ArubaOS 16.06 and later versions?
  • 5.  RE: 2930F number of MSTIs
    Posted Apr 09, 2019 11:56 AM
    Here's the output from a VSF stack:
    2930F-VSF-10G(config)# show span instance
    ist Show the information for the internal spanning tree (IST) instance.
    i will investigate and confirm internally on this and reply back.
  • 6.  RE: 2930F number of MSTIs
    Posted Apr 30, 2019 09:35 AM
    Hello Justin,
    do you have any news?
    regards
    pyrmonte
  • 7.  RE: 2930F number of MSTIs
    Posted Apr 30, 2019 01:43 PM
    It is tested and validated for 16.08 and later.  I would recommend upgrading your switches to that to use 16 instances on a VSF stack.
    Justin
  • 8.  RE: 2930F number of MSTIs
    Posted May 02, 2019 07:53 AM
    Thank you very much Justin.
