2930F switch and VSF with SPF cables
I try to connect 2 switch 2930F whit SPF cables in VSF mode.
My câbles are HPE JH694A
My config :
First switch :
vsf
   enable domain 3
   member 1
      type "JL255A" mac-address 089734-9a9900
      priority 150
      link 1 1/25
      link 1 name "I-Link1_1"
      link 2 1/26
      link 2 name "I-Link1_2"
      exit
   port-speed 10g
   exit
Second switch
vsf
   enable domain 3
   member 2
      type "JL255A" mac-address 089734-9a4a00
      priority 128
      link 1 2/25
      link 1 name "I-Link2_1"
      link 2 2/26
      link 2 name "I-Link2_2"
      exit
   port-speed 10g
   exit
Ports 1/25, 1/26, 2/25 and 2/26 stay fixed orange.
I have allready activate
allow-unsupported-transceiver
When I check I have :
# show interface transceiver detail
Transceiver in 1/25*
   Interface Index    : 25
   Type               : SFP+DAC
   Model              :   ??
   Connector Type     : Vendor specific
   Wavelength         : n/a
   Transfer Distance  : 1m (copper),
   Diagnostic Support : None
   Serial Number      : unsupported
Transceiver in 1/26*
   Interface Index    : 26
   Type               : SFP+DAC
   Model              :   ??
   Wavelength         : n/a
* third-party transceiver
# sh vsf link detail
 VSF Member: 1     Link: 1
 Port     State
 1/25     Error: Hardware failure
 VSF Member: 1     Link: 2
 Port     State
 1/26     Error: Hardware failure
# sh vsf
 VSF Domain ID    : 3
 MAC Address      : 089734-9a9903
 VSF Topology     : No Stack Formed
 VSF Status       : Active
 Uptime           : 0d 0h 37m
 VSF MAD          : None
 VSF Port Speed   : 10G
 Software Version : WC.16.06.0006
 Mbr
 ID  MAC Address       Model                                 Pri Status
  1  089734-9a9900     Aruba JL255A 2930F-24G-PoE+-4SFP+ ... 150 Commander
Does anyone know how to solve it ?
Max
MVP Expert
Re: 2930F switch and VSF with SPF cables
AFAIK VSF doesn't form when unsupported Transceivers or DACs are used for VSF Link(s).
Aruba 2930F supports these two DAC cables:
  • Aruba 10G SFP+ to SFP+ 1 m Direct Attach Copper Cable
    J9281D
  • Aruba 10G SFP+ to SFP+ 3 m Direct Attach Copper Cable J9283D
Hardware revision B (J9281B and J9283B) should be supported too.
So you can eventually try to use unsupported SFP/SFP+ Transceivers or DACs but not to create VSF Link(s).
I suspect the HPE JH694A is the SKU of a old DAC cable unsupported on Aruba 2930F (at least to form VSF Link(s)).
Ok,
The stranger thing is that VSF has worked on my desk.
I put everything in my rack, nothing work.
I remove vsf configuration and configure it again, I plug câbles, ports goes green, the slave switch reboot but after the reboot vsf doesn't work and ports stay orange.
MVP Expert
@FireMax wrote: The stranger thing is that VSF has worked on my desk.
With exactly the same hardware and software configurations?
Yes, exactly the same configuration and hardware (maybe spf cables were interchanged, it's the only thing that can have change).
My IMC discover it correctly when VSF worked on my desk :
1ChassisJL255A(Commander)CN87HKW0W0 1Rev 0WC.16.06.0006WC.16.01.0004
2ChassisJL255A(Standby)CN87HKW0Y0 2Rev 0WC.16.06.0006WC.16.01.0004
Did you find the solution?
I have posted a process to use unsupported third-party transceivers here:
VSF with non-standard transceivers
It should help you plan a solution. Only supported transceivers are recommended in general, but especially for VSF links.
Richard Litchfield, HPE Aruba
Consulting System Engineer
Network Ambassador
