Occasional Contributor I
2930F voice vlan config
Hello everyone, im new to Aruba.. I am replacing the cisco 2950 with aruba 2930f switch.
Right now i have
switchport access vlan 10
switchport voice  vlan 150
on each interface on the cisco switch, whats the equivalent command in aruba?
any help would be appreciate it... also SVI voice vlan recommendation on aruba too..
MVP Expert
Re: 2930F voice vlan config
Greetings!
The equivalent AOS-Switch configuration on the 2930F to what you have configured on your existing switch would be this (replace port list and IP addressing with actual values):
vlan 10
   name "Data"
   untagged 1-24
   ip address 10.0.10.1/24
   exit
vlan 150
   name "Voice"
   tagged 1-24
   ip address 10.0.150.1/24
   voice
   exit
As far as the voice VLAN SVI, could you clarify what kind of recommendation you're asking for?
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
Great, this is exactly what i was looking for..on the interface you specified "voice" do you know whats that for? also is there any recommendation on qos for voice?
Thank you very much
MVP Expert
Thank you very much
it is to configure voice vlan (and qos)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
