Wired Intelligent Edge
2930M Redundant Fault Tolerant Configuration
  • 1.  2930M Redundant Fault Tolerant Configuration
    Posted May 15, 2019 03:47 PM
    I am hoping someone can give me some direction... I have 2 TOR Switches that I am wanting to leverage for FT NICs in ESXI6.7 per vswitch. Problem I am having is finding solid configuration information to do this successfully. I am not looking to stack switches only have NIC1 go to one switch and NIC 2 to go to the other and both switched are cabled to a single core switch. I've tried trunking the Core Switch ports but didn't get the result I was looking for down stream and lost NIC connectivity when attempting to simulate a switch port failure. I've been through the switch configuration guide for the 2930M and vSphere networking guide, but am coming up short in nailing down redundant switch specifics. Thanks.
  • 2.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 15, 2019 05:11 PM
    Do you have a network topology diagram?
    There are a few options
    * Simplest: Use the default settings. No teaming just add two NIC's to the vSwitch and connect the cables to a standard port (not trunk). In case of a failover ESX will send a gARP to make sure the switches will learn the MAC addresses at the new ports
    * Static link aggregation: Connect the two ports to a single logical switch and configure the ports as a trunk port (without LACP). Within ESX you have to configure the vSwitch with the correct Load Balancing configuration. See this (old) article but the basics are the same in 6.7. In this article VMware called it LACP but there is no LACP involved with this config https://kb.vmware.com/s/article/1004048?
    * Same as the previous option but with LACP. For this option you must run distributed vSwitches
    I would say use the first option
  • 3.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 15, 2019 05:27 PM
    Sorry, didn't see the diagram. In this setup just use the default settings. Don't use any teaming options
  • 4.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 16, 2019 10:21 AM
    Thanks Willem - Option 1 is the path I originally went down, but with the loss of the uplink from TOR1 to CoreSW (cable got unplugged) we lost all access which I didn't expect. The path through TOR2 never assumed the traffic restoring the cluster to connectivity. So that's why I started looking at how others were doing it and that's been a convoluded mess. If there is nothing I need to do on the switches then I'll have to work backward through the host networking and see if there is something amiss there. Thanks again.
  • 5.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 16, 2019 11:17 AM
    Okey that is correct. If the uplink is down of the TOR than some traffic is dropped.
    What you can do:
    • Make sure the TOR's have a redundant uplink
    • use the feature uplink failure detection
    Uplink failure detection example
    uplink-failure-detection
    uplink-failure-detection track 1 links-to-disable <esx ports> links-to-monitor <uplink>  delay 30
  • 6.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 16, 2019 12:03 PM
    Ah, I've been behind a desk to long... I think you hit the nail on the head with UFD. UFD does require NICs Teamed NFT correct? or will ESXi manage the link state and failover without designating the uplinks as a Team?
  • 7.  RE: 2930M Redundant Fault Tolerant Configuration
    Posted May 16, 2019 01:59 PM
    If I am reading correctly I can just accept the defaults in the vSwitch for NIC Teaming they appear to be correct for what I need. Thanks for the assist Willem.
