2930M STACKING UPGRADE CONFIGURATION
I have a stack of 7 2930M . And i Would like to know if there is a configuration guide to upgrade the whole stack at once ?
Thank you in advance
Re: 2930M STACKING UPGRADE CONFIGURATION
The process to upgrade a stack is in the Advanced Traffic Management Guide of the Switch Series:
http://h22208.www2.hpe.com/eginfolib/Aruba/16.08/5200-5484/index.html#s_Downloading_New_Software_to_the_Stack_201203140119.html
When you console into the stack, you are using the commander instance.  Once you uploade the firmware, it will copy to the entire stack (all stack members), which you will then need to reboot the stack to load the new code.
Justin
Thank you Justin for your reply :)
Is it the same process to upgrade à switches en VSF topology  ? I need to upgrade only the commander  ?
Also , I have upgraded my switch to the new version WC.16.08.0001 .
Is this version stable ? I am afraid since its the release 0001
Any fixes are generally checked into the newer builds.  All of our builds are rigorously tested each version that is released, so it's safe to upgrade to the latest, you will also be able to implement the new features with 16.08, as well get any fixes from previous versions.
Justin
