MVP Expert
Re: 2930M stacking
@alagoutte: you're too fast... :-)
Occasional Contributor I
Re: 2930M stacking
If we are using True Stacking using Stacking modlue, do we need Aruba 3810M/2930M 4SFP+ MACsec Module - JL083A  to be added to the switch ?
//Since Stacking cable will be only avialable after adding Aruba 3810M/2930M 4SFP+ MACsec Module - JL083A in IRIS Configurator
MVP Expert
Re: 2930M stacking
No
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Re: 2930M stacking
Thanks Sir for your Fastest reply :)
