Highlighted
Occasional Contributor I
Re: 2930M user-role issue
Thank you Cwickline!
So you also had that variable in the enforcement profile and the access tracker some sort of fooling you filling in the variable with the right value, while the switch receives the %{Device:attribute} (like below)?
I got support from TAC for this, they told this works as designed. I feel like submitting a feature request, would you vote for it? :-)
Highlighted
Moderator
Variables are not supported in downloadable user roles. You should be using VLAN names.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Ok, clear. Thank you.
Johan
