Highlighted
2nd DHCP scope on 2930f
The following is the running config, where i defined two DHCP scopes on my 8P 2930f.
VLAN 1 works fine and provides client IP's, however VLAN 20 wont provide any client IP's on ports assigned 1-2
vlan 1
name "DEFAULT_VLAN"
no untagged 1-2
untagged 3-10
ip address 192.168.8.10 255.255.255.0
dhcp-server
exit
vlan 10
name "VLAN10"
tagged 3-6,8-10
ip address 10.10.10.10 255.255.255.0
exit
vlan 20
name "VLAN20"
untagged 1-2
ip address 172.16.20.10 255.255.255.0
dhcp-server
exit
management-vlan 1
dhcp-server pool "IAP"
default-router "172.16.20.10"
dns-server "8.8.8.8"
network 172.16.20.0 255.255.255.0
exit
dhcp-server pool "lab"
default-router "192.168.8.1"
network 192.168.8.0 255.255.255.0
range 192.168.8.50 192.168.8.200
exit
dhcp-server enable
Accepted Solutions
Highlighted
Re: 2nd DHCP scope on 2930f
Range was missing on VLA 20, though it was not mandatory and the scope will just start at .1
Its working fine now
View solution in original post
All Replies
Highlighted
Highlighted
MVP Guru
It's good to have a look here too.
