Highlighted
3810 Dac compatiblity
We are purchasing some 3810's for some new ToR switches. They list the D series DAC cables in the data sheet on the website. We have a bunch of B series DAC cables we would love to reuse. Mostly
J9281B 1m & J9283b 3m. Are they any issues I will run into using the older cables?
Accepted Solutions
Highlighted
MVP Expert
MVP Expert
Re: 3810 Dac compatiblity
They will work without any issues in an 3810M switch.
https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c05115518
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
View solution in original post
All Replies
Highlighted
MVP Expert
MVP Expert
Highlighted
MVP Guru
Aruba 3810M currently supports (no matter the running ArubaOS-Switch software version [*]):
  • J9281B
  • J9281D
  • J9283B
  • J9283D
  • J9285B
  • J9285D
Reference: ArubaOS-Switch and ArubaOS-CX Transceiver Guide (9th Edition) September 2020 (page 59/91).
Note 1: DAC Cables are for use in JL071A, JL072A, JL073A, Jl074A and JL076A when those switch models are equipped with the JL083A Aruba 3810M/2930M 4SFP+ MACsec Module.
Note 2: DAC Cables are for use in JL075A front SFP+ ports or are for use when the JL075A is equipped with the JL083A Aruba 3810M/2930M 4SFP+ MACsec Module.
[*] Always better to run latest software.
