Highlighted
Contributor II
3810M backplane stacking
I have 3 3810M switches. I need to stack it. Can someone list detailed steps to do it?
Accepted Solutions
Highlighted
Re: 3810M backplane stacking
Hi!
The steps for creating a stack start on page 341 of the Advanced Traffic Management guide - https://support.hpe.com/hpsc/doc/public/display?docId=a00050236en_us
Depending on which method you want to use, you can follow the steps in order to create the stack.  Generally the easiest is to have all switches powered off, the cables connected, and power each switch one by one (let the switch fully boot up and join the stack before powering on the next one) and that way, each stack member ID will match the physical switch order.
Justin
View solution in original post
All Replies
Highlighted
MVP Guru
Do you have all necessary Stacking Modules and related Stacking Cables?
Highlighted
Contributor II
Yes everything needed is there.
Highlighted
Hi!
Justin
