4SFP+ MAC sec module
Hi guys,
I need to know the use of the MAC sec module on 3810 switch series. Is it used for stacking, uplink or just simply SFP+ connection
MVP
MVP
Re: 4SFP+ MAC sec module
The 3810M require stacking link modules with stacking cables. The macsec module are simple sfp+ connections with macsec capability.
Stacking Modules
System (std 0 // max=1) User Selection (min 0 / max=1) per Chassis Aruba 3810M 4-port Stacking Module
• min=1 \ max=4 Stacking cables Configuration Rules:
JL084A See Configuration NOTE: 1
J9578A J9665A J9579A
NOTE 1
Uplink Modules
One of the following Stacking Cables must be selected:
Aruba 3800/3810M 0.5m Stacking Cable Aruba 3800/3810M 1m Stacking Cable Aruba 3800/3810M 3m Stacking Cable
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Hey!!
Thanks for the info.
Just to confirm, we can do uplinks on mac sec modules?
MVP
MVP
Yes its also a ‘normal’ sfp+ 10gb uplink
Thanks!
