Highlighted
Occasional Contributor I
[5406] Redundant DHCP Server - Best practice
Hello, I have a scenario with two core switches playing the role of DHCP Server for network stations, what is the best practice for configuring DHCP scopes?
Do I replicate the same DHCP configuration on the two core switches?
It is being configured around 16 DHCP scopes within the limit of 8192 that the 5400 supports.
Note:
Between the two switches the VRRP protocol is enabled.
Accepted Solutions
Highlighted
Re: [5406] Redundant DHCP Server - Best practice
You can configure two different DHCP scope in two core switches but config with different VLAN from each other.
Suresh
View solution in original post
All Replies
Highlighted
Suresh
