5406R zl2 - VSF and BGP routing (same feature set as a single managed chassis?)
Hello everyone,
We are looking at configuring two 5406R zl2 switches as our core switch(es) but we want to use VSF to simplify our topology and configurations (manage configurations as if we had one chassis).  We need to leverage the routing features of the switch (BGP and static routes).
We read through the configuration guide and we understand the limitations (one management module per chassis, 10/40Gb SFP+ for VSF links, v3 modules only, etc...) and the premise that the VSF will create one logical switch across both chassis therefore we can avoid using VRRP for our router redundancy.
I tried finding direct responses to what we are seeking but we couldn't find anything explicitly answering our question.  So before we purchase 10Gb SFP+ v3 modules to put in these chassis to form the VSF, we would like to confirm that using VSF across two chassis will permit us to configure the logical switch in the same fashion as if this was a single chassis switch/router (single BGP instance on logical switch, single router IP for VLANs on logical switch, etc...).
Super Contributor II
Re: 5406R zl2 - VSF and BGP routing (same feature set as a single managed chassis?)
With VSF you have one control plane. This means also one IP address per VLAN for the VSF stack and single BGP instance. This really simplifies the configuration.
Keep in mind that you may need to configure some additional thinks like non stop routing / graceful restart. This will help to failover without loosing BGP neighbors.
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Perfect, thanks willembargeman.
