Highlighted
Occasional Contributor I
5412zl2 and QSFP into Blade Center
Hi
I've had this open for a while on the HP forum;
https://community.hpe.com/t5/Aruba-ProVision-based/QSFP-Configuration-to-Synergy-12000/m-p/7035966#.XHZKnS2cZTb
No one's answered, so I thought I'd try my luck here?
Anyone?
Pete (PeteNetLive)
Accepted Solutions
Highlighted
Re: 5412zl2 and QSFP into Blade Center
Problem solved the -  'sub' oe 'virtual' interfaces on the Synery needed adding to the uplink group
See
HPe Synergy 12000 MPIO QSFP to 10GB SFP Setup
Pete
View solution in original post
All Replies
Highlighted
MVP Guru
"for a while" is not the case...you just wrote it on Monday February 25th...two days ago!
Are you sure you don't need to configure LACP on ports on the Synergy side? it seems like first port of each QSFP going to separate Switch (Slot 3 and Slot 6) - Synergy side - is unblocked and remaining ports are blocked...are both Switches - Synergy side - deployed as an IRF (so they appear as a logical Switch to the Aruba 5400R zl2) in order to use a LACP with links spanning to both Synergy Switches (Slot 3 and 6)?
Highlighted
Hi - Yeah Sorry, I'm in forums a lot, Usually on the answering side at Cisco and Experts Exchange, 2 days is a long time for me !
Anyway, to answer, LACP IS setup on the Synergy it configures it by default when you create an 'uplink group', with no interaction. The latest firmware (which I put on last week, let's you change the LACP load balancing algorythm, but its on 'select based on  source ip and mac, and destination ip and mac' anyway.
Pete
Highlighted
Update: Got a call open with the Aruba support team, they tell me they can not see any misconfiguration on the 5412.
They are contacting the Synergy team to see if this is default behaviour
Regards
Pete (PeteNetLive)
Highlighted
See
Pete
