Wired Intelligent Edge
802.1x Auth on Switch-Port with Access-Points
  • 1.  802.1x Auth on Switch-Port with Access-Points
    Posted Sep 11, 2020 03:54 AM
    I have a customer with 2530 Switches and MSM430 Access-Points- We are using 802.1x with EAP-TLS, PEAP and MAC Authentication.
    The APs do not tunnel the client traffic to the wifi controller.
    I have configured the APs to authenticate over PEAP what is working fine.
    But clients are connected to wife on a access-point do not get a network connection because of the local breakout to the network.
    Device Profiles are not working with MSM Access-Points. How can I do authentication the Switch-Ports with a connected access-point?
    This is the Port-Config
    aaa port-access authenticator 1
    aaa port-access authenticator 1 client-limit 1
    aaa port-access supplicant 1
    aaa port-access mac-based 1
    aaa port-access mac-based 1 unauth-vid 6
    THANKS
  • 2.  RE: 802.1x Auth on Switch-Port with Access-Points
    MVP GURU
    Posted Sep 11, 2020 08:09 AM
    You need to push device mode
  • 3.  RE: 802.1x Auth on Switch-Port with Access-Points
    Posted Sep 15, 2020 02:53 PM
    Can you please give me little more support?
  • 4.  RE: 802.1x Auth on Switch-Port with Access-Points
    Posted Sep 22, 2020 03:05 AM
    It works when I remove MAC-Auth on the Ports where an AP is connected.
