80plus.org Certification
Hi, does anyone knows the 80plus.org certification level (if any) for JL086A, JL087A, JL088A, JL372A, JL480A, JL632 and JL633?
I think this information is very important but it is not included for high-end switches (the ones very likely to be installed in large datacenters).
