8200 / 5400R zl2 and multiple sets of RADIUS servers
We need to share a couple of switches (HP/ Aruba 8212 / 5412R / 5406R) between two organizations.
Each organization has its own set of VLANs and uplinks.
Both use IEEE-802.1x and have their own RADIUS servers.
Is it possible to configure two independent sets of RADIUS servers and set for each port which servers to be used for 802.1x auth?
MVP Expert
Re: 8200 / 5400R zl2 and multiple sets of RADIUS servers
Greetings!
Per-port RADIUS server group configuration is available for MAC authentication (not 802.1X, at present) as of the 16.08 software release. This can be run on the 5400R models, but not the 8212zl — the last major release for this model was K.15.18.
Matthew Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com
