Highlighted
Regular Contributor II
8320 VLAN ACL
Does anyone know when the 8320’s will support an ACL being applied to a VLAN interface?
Alternatively does anyone know another way to achieve this on a VLAN ... on an interface wont work for what I’m trying to do.
Accepted Solutions
Highlighted
MVP Guru
Re: 8320 VLAN ACL
you need to enter "apply access-list ip|ipv6|mac name in" in the vlan
(not the L3 vlan interface).
View solution in original post
All Replies
Highlighted
Re: 8320 VLAN ACL
The 8320 switch support extended ACL and in that VLAN ACL(VLAN-ACL) as well.
for configuring the VLAN based ACL find the below configuration template.
1) configure the extended ACL name
SW(config)# ip access list  extended < name>
2) configure the rules that permit the traffic or deny the traffic like
SW( config-ext-NaCl) # permit udp any host 10.x.x.x eq boots
apply the ACL inbound to vlanxx
SW(config)# VLAN xx IP access-group name in
Aruba is providing the one advanced switching course ( Implementing the campus switching)
https://certification-learning.hpe.com/tr/datacard/Course/01095999
Highlighted
MVP Guru
Re: 8320 VLAN ACL
It is supported since release 10.2.
Highlighted
Re: 8320 VLAN ACL
Thanks ... I’m running version
TL 10.02.0010
I don’t see the support for those commands on this ArubaOS-CX?
Went into the conf mode ... vlan 100 - everything else after the vlan 100 doesn’t allow further options?
Tried going into the vlan interface to apply a access list but no options there either?
Highlighted
MVP Guru
Re: 8320 VLAN ACL
Highlighted
Re: 8320 VLAN ACL
Perfect - thanks
Highlighted
Re: 8320 VLAN ACL
Is there anything related to arubaos-cx training on the inter-tube similar to the excellent cisco based cbt-micro-nuggets for arubaos-cx ????
../smb/air
