Highlighted
Regular Contributor II
8320 passive interface default
On my 8320 I can see under the router OSPF commands an option to enter passive interface default.
I couldn’t see an option to turn off this command one interface at a time (no passive interface 1/1/1)
How do you allow for certain ports ... or is the switch smart enough to see which ports you have configured for OSPF under this command?
Accepted Solutions
Highlighted
MVP Expert
Re: 8320 passive interface default
Greetings!
You can configure individual interfaces as passive OSPF ports from the interface context:
switch(config)# interface 1/1/1
switch(config-if)# ip ospf passive
Matt Fern
Senior Technical Marketing Engineer, Aruba Switching
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
View solution in original post
Highlighted
MVP Guru
Simply no ip ospf passive on the interface.
Here is an example of SVI with ospf:
interface vlan251
vrf attach prod
ip address 10.1.251.2/29
ip ospf 10 area 0.0.0.0
no ip ospf passive
ip ospf cost 100
All Replies
Highlighted
MVP Expert
Greetings!
Matt Fern
Highlighted
Thanks, that’s great
Highlighted
MVP Guru
If I may, FYI, a best practice applied I saw on many large ITs, is to passive all interface and activate only the one that should be active.
Highlighted
Would that look like
Router OSPF 1
Passive interface default
Interface 1/1/1
IP OSPF 1 area 0 - this bit here is what I’m unsure about?
Does this command override the passive interface default?
Highlighted
MVP Guru
interface vlan251
vrf attach prod
no ip ospf passive
ip ospf cost 100
Highlighted
Excellent - thanks for that
