Wired Intelligent Edge
8400 Active Optical Cable (AOC)
  • 1.  8400 Active Optical Cable (AOC)
    Posted May 22, 2019 11:46 AM
    Hello everyone,
    does anyone know if the AOC cable (Aruba 40G QSFP+ to QSFP+ 30m AOC - R0Z24A) works on the Aruba 8400 Switch (I/O slot 8400x 8p 40G QSFP+ Adv Module - JL365A)?
    At the moment the datasheet doesnt mention active optical cables to 8400, just for 8325.
    #8400
  • 2.  RE: 8400 Active Optical Cable (AOC)
    MVP GURU
    Posted May 22, 2019 06:27 PM
    AFAIK Aruba 8400's QuickSpecs (March, 4th 2019 Version 11) doesn't report any support for AOC options...the very same is true for latest ArubaOS-Switch and ArubaOS-CX Transceivers Guide (6th Edition, January 2019)...OTOH latest Aruba 8325's QuickSpecs (May, 6th 2019 Version 6) instead states that AOCs are supported (R0M44A, R0M45A and R0Z21A respectively 3, 7 and 15 meters 25G SFP28 to SFP28 AOCs).
    Consider that Aruba 8400 hasn't an interface card with ports supporting SFP28 (1/10/25Gbps)...so that could be the reason.
  • 3.  RE: 8400 Active Optical Cable (AOC)
    Posted May 22, 2019 08:13 PM
    At this time (May, 2019), only the 8325 has been qualified to work with the 40G AOCs:
    • Aruba 40G QSFP+ to QSFP+ 7m Active Optical Cable (R0Z22A)
    • Aruba 40G QSFP+ to QSFP+ 15m Active Optical Cable (R0Z23A)
    • Aruba 40G QSFP+ to QSFP+ 30m Active Optical Cable (R0Z24A)
    Qualification for 40G AOC support on the 8400 will be coming in a future timeframe (sorry, can't commit at this time).
    the 25G AOCs: ONLY supported on the 8325
    • Aruba 25G SFP28 to SFP28 3m Active Optical Cable (R0M44A)
    • Aruba 25G SFP28 to SFP28 7m Active Optical Cable (R0M45A)
    • Aruba 25G SFP28 to SFP28 15m Active Optical Cable (R0Z21A)
    And correct, the 8400 does not have a 25G module, so no support for 25G products on the 8400.
  • 4.  RE: 8400 Active Optical Cable (AOC)
    MVP GURU
    Posted May 22, 2019 08:52 PM
    It's a pleasure to receive a feedback by @EdKurata! really...you're a master!
