AAruba 2920 - Cisco 8851 Phone with AKEM Sidecar Does Not Power Up Completely
MVP
MVP
Problem:
A 2920 running WB.16.04.0008 with a cisco 8851 phone that has a AKEM sidecar attached does not power up all the way. The show power int x/x command shows the phone is requesting 11.8 watts and getting only 8.6 watts. So the sidecar never really powers up all the way.
Upgrading to wb.16.06.0006 fixes the issue.
Diagnostics:
show power interface x/x
The phone will request 11.8 watts and only get 8.6 watts.
Solution
Upgrading to wb.16.06.0006 fixed the issue
Version history
Revision #:
1 of 1
Last update:
‎01-28-2019 10:59 AM
Updated by:
