can I know where the VLAN 2 & VLAN 3 gateway configured?
If the gateways are configured on the same switch then all end will communicate using local and direct routes from the gateway?
and if VLANs gateways are in different switches then required routing and ACL are required to configure.
Best Regards,
Suresh
