Contributor II
AOS-CX 10.03..31 <<< debug acl all sev debug (wr mem)
RE:  AOS-CX 10.03..31 <<< debug acl all sev debug (wr mem)
See attached TXT file that is the result of SHOW DEBUG.
All "attached" DEBUG commands were entered in the command/CLI mode and NOT in the configuration context.
ALL DEBUG changes were retained during the boot process except: >>> debug acl all sev debug
I had to save the configuration using "wr mem" or save the configuration during the BOOT process.
Is saving the "debug acl all sev debug" parameters a correct AOS-CX 10.03.0031 configuration requirement?   Or a BUG ?
MVP Expert
Re: AOS-CX 10.03..31 <<< debug acl all sev debug (wr mem)
may be a bug..
do you have try if other debug is kept after reboot ?
it will be a good idea to open a case on TAC
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
