Wired Intelligent Edge
AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks ???
  • 1.  AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks ???
    Posted Oct 02, 2019 01:37 PM
    One question @ end of this post.
    Re: AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks
    The AOS-X manuals mention SUBNET-MASK when discussing ACL/ACE.
    The following SYSTEMS use network Access-List WILDCARD Masking:
    HP PRocurve
    HPE Provision
    ArubaOS Switch
    Cisco
    It appears HPE ArubaOS-CX uses SUBNET-MASK and not wildcarding:
    A.B.C.D         Specify source IP host address
    A.B.C.D/M     Specify source IP network address with prefix length
    A.B.C.D/W.X.Y.Z    Specify source IP network address with network mask
    NAME            Specify source IP address group
    any                 Any source IP address
    QUESTION:
    HPE AOS-CX ACL MASKING is just opposite of the previosly mentioned SYSTEMS?  Is my interpretation correct???
    thanks...gracias....danke....merci
  • 2.  RE: AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks ???
    MVP GURU
    Posted Oct 02, 2019 03:12 PM
    Yes CX use a "normal" masking (and not wildcard like before...)
  • 3.  RE: AOS-CX 8320 <<< ACLs SUBNET-MASK versus WILDCARD Masks ???
    Posted Oct 19, 2023 10:12 AM
    Sorry to ressurrect this thread, but does that mean you are no longer able to make "intelligent" masking of certain bits using the subnet mask?
    FX: On procurve you could permit traffic to 172.16.0.0/16 and 172.24.0.0/16 using a one liner like this:
    permit ip any 172.16.0.0 0.8.255.255
    Is this no longer possible with CX, or does it do the same thing using bits set to zero in the subnet mask to indicate which hostbits to ignore?
    aka: permit ip any 172.16.0.0/255.247.0.0 ?
