Contributor II
AOS-CX-VLAN-ACLs << (VACLs) Hints&Observations
VLAN Access-List Learning experience on an 8320 running 10.03+:
CONFIG CONTEXT:
vlan 200
description SERVER-VLAN
apply access-list ip VLAN-SERVER-200-IN-# in
exit
access-list ip VLAN-SERVER-200-IN-1
9 comment SERVER-200 >>>>>>>>>>>>>>>>>> VACL INBOUND
90 permit any 0.0.0.0 0.0.0.0 count
99 deny any 0.0.0.0 0.0.0.0 log count
exit
access-list ip VLAN-SERVER-200-IN-2
90 permit any 0.0.0.0/0 0.0.0.0/0 count
99 deny any 0.0.0.0/0 0.0.0.0/0 log count
exit
VLAN-SERVER-200-IN-1 does NOT equal VLAN-SERVER-200-IN-2
OBSERVATIONS:
VLAN-SERVER-200-IN-1 resticts only host 0.0.0.0.
No hitcounts were observed and no logs were sent to the syslog server. After seq#99 there is an IMPLICIT DENY w/o logs or counts.
MVP Expert
Re: AOS-CX-VLAN-ACLs << (VACLs) Observations
yes it is normal...
0.0.0.0 is also an (special) ip address... for ALL ip adresse need to use 0.0.0.0/0
it is always better to specific the netmask...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
