Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
AOS-CX: retarting the SSH process (sshd) ?
Re:  root 2117 1 0 Jun04 ? 09:15:03 python /usr/bin/hpe_sshd
What is a command that will restart the SSH (sshd) process via start-shell or other "console" you are willing to share?
Part of the reason I wish to restart is to eliminate what appears to be orphaned logged admins:
HPE-AOSCX8320-Branch1:~$ ps -ef | grep ssh
root                                 2117           1   0 Jun04 ? 09:36:00 python /usr/bin/hpe_sshd
root                                 4290     2117   0 Jul14 ? 00:00:00 sshd: hpe-aoscx-admin [priv]
hpe-aoscx-admin           4305      4290   0 Jul14 ? 00:00:03 sshd: hpe-aoscx-admin@pts/4
root                                5557      2117    0 02:00 ? 00:00:00 sshd: hpe-aoscx-admin [priv]
hpe-aoscx-admin           5570      5557    0 02:00 ? 00:00:00 sshd: hpe-aoscx-admin@pts/1
hpe-aoscx-admin           5693      5616    0 02:00 pts/1 00:00:00 grep ssh
root                              17940       2117    0 Jul14 ? 00:00:00 sshd: hpe-aoscx-admin [priv]
hpe-aoscx-admin         17953     17940   0 Jul14 ? 00:00:02 sshd: hpe-aoscx-admin@pts/5
root                              19948             1    0 Jun04 ? 00:00:00 /usr/sbin/sshd -o PidFile=/var/run/sshd-ns_wireless_mgmt.pid
root                                 31641     2117   0 Jul14 ? 00:00:00 sshd: hpe-aoscx-admin [priv]
hpe-aoscx-admin           31658    31641   0 Jul14 ? 00:00:02 sshd: hpe-aoscx-admin@pts/3
../smb/air
Accepted Solutions
Highlighted
MVP Guru Elite
Re: AOS-CX: retarting the SSH process (sshd) ?
Try on ArubaCX OVA/VM ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
View solution in original post
All Replies
Highlighted
MVP Guru Elite
do you have try with service ssh(d?) restart
Highlighted
Sorry,  I am confused about your response.
If you are asking, "have I tried anything to restart,"  I have not.
I am remote using SSH and if I try something and that does not restart sshd, I can no longer remote access.
../smb/air
Highlighted
MVP Guru Elite
Highlighted
Most excellent idea !!!
../smb/air
Highlighted
MVP Guru
Pay attention to the difference between sshd daemon and hpe-sshd daemon...
