Wired Intelligent Edge
Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
  • 1.  Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    Posted Jul 05, 2019 05:39 AM
    Hi!
    We have couple of Vendor Class Id = HP J9775A 2530-48G Switch and they can connected with each other via LAG LACP.
    Some times when I am typing command on the CLI then it process the command really slow and if I check the cpu usage then I see something like below and if 1 sec ave is above 30 percent then its always slow while typing the command and if its below 30 or some low value then its fine.
    23 percent busy, from 2 sec ago
    1 sec ave: 37 percent busy
    5 sec ave: 14 percent busy
    1 min ave: 5 percent busy
    I have seen this save behaviour in one of our remote office on just one Aruba 2530 24 port switch and on that location we have 3 more 2530-48G but didnt see this issue there.
    I also have few 2530-48G on another remote location but they dont have this issue.
    I am not sure what it can be? Can it be some old broken cable connected to it or something else?
    Can you suggest how can I trouble shooth this?
  • 2.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    MVP GURU
    Posted Jul 05, 2019 06:26 AM
    There is a specific thread already opened about this issue...to me it's unclear if there is a Ticket open or not...what I notice is that Aruba 2530 shows high CPU levels on some time windows...personally I had no time to dig deeper because mainly we deal with Aruba 2540 and our infrastructure owns only two Aruba 2530.
  • 3.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    Posted Jul 05, 2019 06:33 AM
    Thanks for your reply.
    Yes its only some time window and not always.
    Do you think this will effect the performance?
  • 4.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    Posted Jul 08, 2019 10:09 AM
    Anyone suggest something related to this issue?
  • 5.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    MVP GURU
    Posted Jul 08, 2019 10:33 AM
    I just want to add that 16.09.0001 doesn't seem (directly or indirectly) to address random SSH CLI slowness...personally I'm still observing CPU spiking pretty high (I saw 60% too) on just typing - blindly - a particular letter (or deleting) continuosly...so sometime the CLI feedback slows down or, at worst, it freezes...to recover immediately just a second or two after.
  • 6.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    Posted Jul 08, 2019 10:50 AM
    Yes. so what can be the solution :).
  • 7.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    Posted Jul 08, 2019 01:23 PM
    Solution perhaps involves complaining to TAC.
  • 8.  RE: Aruba 2530-48G Switch AVG CPU above 30 act slowly while typing the command
    MVP GURU
    Posted Jul 08, 2019 07:54 PM
    Better than complaining to TAC...providing TAC the evidence there is an issue going on (by opening a Ticket and loading all the relevant information gathered to let them to reproduce the issue).
