This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
Aruba 2530 - Daylight Time
Hi, how set Daylight Time Rule (user-defined) for last Sunday of March and last Sunday of October. This is DTS for Poland/Warsaw.
THX
Highlighted
MVP Guru
Re: Aruba 2530 - Daylight Time
time daylight-time-rule western-europe
Highlighted
I'am test this and not work. This change work back ? after date when time change or only trigger this day ?
Highlighted
MVP Guru
To disable:
time daylight-time-rule none
The switch internally works in UTC, so just the representation is changed not the clock itself.
If you want to set the time for Poland, in addition to the daylight-time-rule, you should set the time offset:
time timezone 60
If you then configure NTP, all should be set:
timesync ntp
ntp unicast
ntp server 192.168.1.1
ntp server 192.168.4.1
ntp enable
Replace the IP addresses with your NTP IP addresses.
