Aruba 2530 - Web access by HTTPS whitout certificate
Is it possible to use the HTTPS protocol without using a certificate in Aruba 2530 ?
THX
MVP Expert
MVP Expert
Re: Aruba 2530 - Web access by HTTPS whitout certificate
no. https by design needs at least server certificates.
You can use a self singed cert on the switch. Or you can use one signed by a trustworthy CA (for management access this typically will be an internal CA). But you can not use https without certificate.
Regards, Jörg
Please give kudos, if you like my post.
Please Accept as solution, if my post was helpful.
