Occasional Contributor I
Aruba 2530 port 48 connect trunk port 48 to Cisco catalyst
We have Aruba 2530 48 PoE+ we are trying to have connected to the Cisco Catalyst. While we are waiting to receive SFPs we are trying to connect port 48 rj-45 port to the cisco Catalyst.
Cisco:
Re: Aruba 2530 port 48 connect trunk port 48 to Cisco catalyst
Success,
I had to first change the default vlan to dhcp then put the manual IP into the net admin vlan then disable the default vlan, then reboot switch.
Also made this change was made on cisco:
I had the switch do a couple core dumps when I was changing the ip configuration, maby a bug in the firmware.
