Aruba 2920 Switch - How can an Automated Backup of the Startup Configuration be Enabled?
MVP
MVP
Q:
How can an automated backup of the startup configuration be enabled?
A:
In the following example, the startup configuration file CONFIG1 is scheduled to be saved to a TFTP server at 10:00 PM.
********** Job Configuration/Verification **********
Rack2sw1# show config | include job
job "Backup-Config" at 22:00 " copy config config1 tftp 10.181.252.102 Rack2sw1.Backup oobm"
Rack2sw1# show job Backup-Config
 Job Information
  Job Name       : Backup-Config
  Runs At        : 22:00
  Config Save    : No
  Repeat Count   : --
  Job Status     : Enabled
  Running Status : Active
  Run Count      : 1
  Error Count    : 0
  Skip Count     : 0
  Command        :  copy config config1 tftp 10.181.252.102 Rack2sw1.Backup
 oobm
  Last Run Time  : Sat Jan  5 22:00:00 2019
  Output from Last Run
TFTP download in progress.
001M
********** Job Execution Verification **********
Rack2sw1# show logging -r
 Keys:   W=Warning   I=Information
         M=Major     D=Debug E=Error
----  Reverse event Log listing: Events Since Boot  ----
I 01/06/19 22:00:13 04612 job: Job 'Backup-Config' completed
I 01/06/19 22:00:13 00131 tftp: Transfer completed
Version history
Revision #:
1 of 1
Last update:
‎03-30-2020 11:02 AM
Updated by:
