Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Aruba 2920 Switch – How is a Syslog server configured?
MVP
MVP
Q:
A:
In the following example the switch is configured to use the Syslog server at the IP address 10.254.1.1.
********** Syslog Configuration/Verification **********
Rack2sw1# show config | include logging
logging 10.254.1.21
Rack2sw1# show syslog config
 Syslog Facility : user
 Syslog Severity : debug
 Syslog System Module : all-pass
 Syslog Priority Description :
 Syslog Server Details
  Syslog Server Address/Host Name     L4  Port   Syslog Control Descr PerIp
  10.254.1.21                         UDP 514                         No
********** Trigger the Syslog message 184 **********
Rack2sw1# clear logging
Rack2sw1# show logging -r
 Keys:   W=Warning   I=Information
         M=Major     D=Debug E=Error
----  Reverse event Log listing: Events Since Boot  ----
I 01/02/90 06:24:19 00184 mgr: Log cleared as a result of  'clear logging'
            command
----  Top of Log : Events Listed = 1  ---
********** Wireshark Trace **********
Ethernet II, Src: 94:18:82:a3:65:40 (94:18:82:a3:65:40), Dst: Vmware_95:5b:6f (00:50:56:95:5b:6f)
Internet Protocol, Src: 10.254.1.2 (10.254.1.2), Dst: 10.254.1.21 (10.254.1.21)
User Datagram Protocol, Src Port: syslog (514), Dst Port: syslog (514)
Syslog message: USER.INFO: Jan  2 06:24:19 10.254.1.2 00184 mgr:  Log cleared as a result of 'clear logging' command
    0000 1... = Facility: USER - random user-level messages (1)
    .... .110 = Level: INFO - informational (6)
    Message: Jan  2 06:24:19 10.254.1.2 00184 mgr:  Log cleared as a result of 'clear logging' command
Version history
Revision #:
1 of 1
Last update:
‎01-07-2019 10:18 AM
Updated by:
