Aruba 2920 Switch – How is the DHCP relay agent configured?
MVP
MVP
Q:
A:
In the following example the DHCP relay is configured server at the IP address 10.254.1.21.
Rack2sw1# show running-config vlan 1
Running configuration:
vlan 1
   name "DEFAULT_VLAN"
   no untagged 1-15
   untagged 16-24
   ip helper-add
Rack2sw1# show ip helper-address vlan 1
 IP Helper Addresses
  IP Helper Address
  10.254.1.21
Rack2sw1# show dhcp-relay
 Status and Counters - DHCP Relay
  DHCP Relay Agent                 : Enabled
  DHCP Request Hop Count Increment : Enabled
  Option 82                        : Disabled
  Response validation              : Disabled
  Option 82 handle policy          : replace
  Remote ID                        : mac
  DHCP Relay Statistics:
  Client Requests       Server Responses
  Valid      Dropped    Valid      Dropped
  6          0          6          0
  DHCP Relay Option 82 Statistics:
  0          0          0          0
Version history
Revision #:
1 of 1
Last update:
‎01-07-2019 10:23 AM
Updated by:
