Aruba-2930F-24G-4SFP ( Layer 3)
 have a switch Aruba-2930F-24G-4SFP ( Layer 3)  But i have a problem about configuration CLI in HP
1) i know this commande  in Ciscobut i don't know in Aruba-2930F-24G-4SFP ( Layer 3)
interface  ethernet  1===> link with switch layer 2 ( DLINK)
switch trunk enpasulation dot1Q
switchport mode trunk
how i can configure this CLI  in switch layer 3  HP 2930F:  traduction to HP
thanks in advance i a answer ASAB
Contributor I
Re: Aruba-2930F-24G-4SFP ( Layer 3)
int X untag vlan Y
where X is the interface identifier in the Aruba switch, Y is the vlan or list of VLANs you want tagged in 802.1q to traverse that port.
Contributor I
see the file in attachment, CLI reference Guide. (equivalance between aruba and cisco)
Mathias Troncoso-Aballay
ACMP, ACCP, ACSA | Aruba Partner Ambassador
MVP Expert
Personally, given your Cisco versus ArubaOS-Switch commands translation doubts (especially against VLAN tagging and Link Aggregation),...I think this is always illuminating.
Hello
i have a problem that switch Aruba-2930F-24G-4SFP don't give any address dhcp to PC : i have two vlan 10 and vlan 20
this switch is link to switch DLINK1210-28p
so i need a help why pc don't recive any address from pool vlan 10 ?,
i give scrpit about HP layer 3 and i need answer ASAB
PLease some one can access with team viwer to have idea about problem swith as preffer
please i nees answer urgent about switch layer 3 don't give any pool to desktop
thanks in advance
Aruba-2930F-24G-4SFP# show dhcp-server
Configuration and Status - DHCP Server
DHCP Server Enabled : Yes
DHCPv4 Operational Status : Enabled
Traps Enabled : Yes
Persistent Lease Database : No
Conflict Logging Enabled : No
DHCP VLAN Interfaces :
Contributor I
seems that u don't have configured properly the dhcp configuration... missed some configuration
Please follow these steps and let me know
https://www.networktasks.co.uk/environments/hp/provision/dhcp-server-on-hpe-aruba-switch
help me and give me commands missing that allow DHCP switch to give desktop
i wait to answer urgent
thanks in advance
Contributor I
you have to create your vlan and assign that vlan the dhcp-server enable
but before that, your config of the dhcp-server should look like that
dhcp-server pool "VLAN-NAME"
authoritative
default-router "192.168.0.1"
dns-server "8.8.8.8,8.8.4.4"
domain-name "test.local"
lease 00:01:00
network 192.168.0.0 255.255.254.0
range 192.168.0.21 192.168.1.149
