Re: Aruba-2930F-24G-4SFP ( Layer 3)
i wait your answer about my explain architechture link abou two switch
please it urgent for my work in company
please  you can access about 10 minute by team viewer that i can undertstand and i give information about solution
Contributor I
Sorry about that but i'm on training right now,
please tagged you interfaces in the Aruba switch side... your dlink switches seems to be fine...
if that is not working i suggest you to contact de TAC
https://www.arubanetworks.com/fr/service-technique/contactez-le-support/
Mathias Troncoso-Aballay
ACMP, ACCP, ACSA | Aruba Partner Ambassador
in the switch Aruba-2930F-24G-4SFP ( Layer 3)
what is command  that allow in port 1 is trunk  (switch layer 3)  to switch layer 2 !!
only that command my be dhcp work
thanks in advance
what is cammand can check if port 1 switch layer 3 is trunk in  Aruba-2930F-24G-4SFP ( Layer 3)
please i thanks very much to answer me
please can you reply !!
thanks
MVP Expert
You look like in big trouble...but every time you received an help (someone told you to untag at least one port on a specific VLAN on the Aruba to test if DHCP is OK or not) you didn't.
So:
  1. Untag one or more ports on VLAN 10 or 20 (the command is: vlan 10 -> Enter -> untagged 4 then exit to exit the VLAN 10 context you entered <-- this series of commands will cause port 4 to became untagged member of VLAN 10)...at that point a PC connected to port 4 with its NIC port set to DHCP will receive an IP Address from the Aruba in VLAN 10 or 20. To check the status of a port from the VLAN membership standpoint use the command show vlan port n detail where n is the physical or logical (trkX) port id. Remember to write memory to save your configuration running configuration to startup configuration on your Aruba.
  2. The port you use to interconnect your Aruba (Layer 3: doing IP Routing) and your D-Link (doing what?) is probably Port 1 on both the Aruba and the D-Link. OK...so you need to match VLAN tagging on both ends...you trunk 1 trk1 trunk is TOTALLY WRONG! you haven't a link aggregation (trunk trk1)...you said you have JUST one physical link between Aruba and D-Link so forget about trunk trk1...you must remove trk1 with no trunk trk1 and then Port 1 will be reset to be untagged member of VLAN 1...then you MUST tag others two VLAN id (10 and 20) you need for speaking with D-Link with the command: interface ethernet 1 vlan tagged 10,20...doing so if you perform a check with show vlan port 1 detail you will discover that Port 1 will be concurrently untagged member of VLAN 1 (like in D-Link Port 1) and tagged member of VLAN 10 and 20 (again, like in D-Link Port 1...as per your screenshot).
  3. If you're able to do that you should be OK, if not you need to contact anyone that will be able to help you directly (TAC, Distributor, Consultant)...I suspect nobody here have the time (nor will take the responsability) to perform a remote session to fix your issues in real time as you want <-- and that's because you didn't explain what was/is your scenario...you just throw an issue after the other waiting for help.
I am a network engineer thanks very much about your  detail and tthat's what I want and  will feedback about result to morrow that is fine or not !
thanks
Hello
i changed configuration but nothing work !!
Aruba-2930F-24G-4SFP# show running-config
Running configuration:
; JL259A Configuration Editor; Created on release #WC.16.09.0001
; Ver #14:27.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:04
hostname "Aruba-2930F-24G-4SFP"
module 1 type jl259a
ip routing
interface 1
flow-control
exit
snmp-server community "public" unrestricted
vlan 1
name "DEFAULT_VLAN"
untagged 1-28
ip address dhcp-bootp
ipv6 enable
ipv6 address dhcp full
exit
vlan 10
name "RH"
tagged 1
ip address 10.10.10.1 255.255.255.0
dhcp-server
exit
vlan 20
name "office"
tagged 1
ip address 20.20.20.1 255.255.255.0
dhcp-server
exit
dhcp-server pool "RH"
authoritative
default-router "10.10.10.1"
network 10.10.10.0 255.255.255.0
range 10.10.10.2 10.10.10.254
exit
dhcp-server pool "security"
authoritative
default-router "20.20.20.1"
network 20.20.20.0 255.255.255.0
range 20.20.20.2 20.20.20.254
exit
dhcp-server enable
Aruba-2930F-24G-4SFP# show vlans ports 1 detail
Status and Counters - VLAN Information - for ports 1
VLAN ID Name | Status Voice Jumbo Mode
1 DEFAULT_VLAN | Port-based No No Untagged
10 RH | Port-based No No Tagged
20 office | Port-based No No Tagged
Aruba-2930F-24G-4SFP# ping 10.10.10.40
Request timed out.
Aruba-2930F-24G-4SFP# write memory
Aruba-2930F-24G-4SFP# show RUNning-config
ip routing
interface 1
flow-control
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-28
ipv6 enable
exit
vlan 10
name "RH"
tagged 1
dhcp-server
exit
vlan 20
name "office"
tagged 1
dhcp-server
exit
authoritative
exit
authoritative
exit
dhcp-server enable
i send screnn shot about ping from addres ip static vlan 20 to gateway 20.20.20.1
but noting work !!
so what i can do to check or to configure switch layer 3 !!
please i need a help urgent
i changed configuration for switch layer 3
but noting work
please i need a reply what i can configure or check or edit this configuration
pc don't get dhcp from vlan 10 !!!!!!!!!!!!!???????????????,,,
ip routing
interface 1
flow-control
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-28
ipv6 enable
exit
vlan 10
name "RH"
tagged 1
dhcp-server
exit
vlan 20
name "office"
tagged 1
dhcp-server
exit
authoritative
exit
authoritative
exit
dhcp-server enable
ip routing
interface 1
flow-control
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-28
ipv6 enable
exit
vlan 10
name "RH"
tagged 1
dhcp-server
exit
vlan 20
name "office"
tagged 1
dhcp-server
exit
authoritative
exit
authoritative
exit
dhcp-server enable
MVP Expert
You didn't untag ANY port on the relevant VLAN (10 or 20) you want to test...AGAIN...there aren't access port untagged member of VLAN 10 or VLAN 20...so what are you pretend to test if the configuration is missing a piece?
Who is 10.10.10.40 you're trying to ping from the Switch console?
Where is the host supposedly having that IP connected to (port)?
Go to Step 1 and untag THAT port on VLAN 10 with the command we gave you before many times: enter VLAN 10 context with the vlan 10 commmand, execute the untagging with the command untagged port-number (where port-number is the Port where there is the host you are trying to ping on VLAN 10)...then exit the vlan context with exit, do a write memory...and finally do a show vlan port port-number detail to check that the configuration you did for that port is OK from the VLAN tagging/untagging standpoint.
You wrote us you're a Network Engineer so you should have easy time doing such changes, it's not rocket science, really (clearly you need a basic understanding of CLI, configuration and VLANs...not necessarily Cisco biased).
