Aruba-2930M Switch - How to query the SNMP OIDs for the “Out Of Band Management Port”
MVP Expert
MVP Expert
This article discusses how to query the SNMP OIDs for the “Out Of Band Management Port” using the walkMIB CLI command.
In the following example, the out of band management port configuration and statistics are displayed.
Aruba-2930M-48G# walkmib ifDescr | include Port
ifDescr.4883 = Out Of Band Management Port
Aruba-2930M-48G# walkmib 1.3.6.1.2.1 | include 4883
ifIndex.4883 = 4883
ifType.4883 = 6
ifMtu.4883 = 1500
ifSpeed.4883 = 100,000,000
ifPhysAddress.4883 = f4 03 43 d8 2a 81
ifAdminStatus.4883 = 1
ifOperStatus.4883 = 1
ifLastChange.4883 = 18 secs
ifInOctets.4883 = 520,500
ifInUcastPkts.4883 = 110
ifInNUcastPkts.4883 = 80
ifInDiscards.4883 = 0
ifInErrors.4883 = 0
ifInUnknownProtos.4883 = 0
ifOutOctets.4883 = 8148
ifOutUcastPkts.4883 = 108
ifOutNUcastPkts.4883 = 0
ifOutDiscards.4883 = 0
ifOutErrors.4883 = 0
ifOutQLen.4883 = 0
ifSpecific.4883 = zeroDotZero
ipAdEntIfIndex.10.181.243.109 = 4883
ipv4InterfaceReasmMaxSize.4883 = 65,535
ipv4InterfaceEnableStatus.4883 = 1
ipv4InterfaceRetransmitTime.4883 = 100
ipv6InterfaceReasmMaxSize.4883 = 1500
ipv6InterfaceIdentifier.4883 = f6 03  43 ff   fe d8  2a 81
ipv6InterfaceEnableStatus.4883 = 2
ipv6InterfaceReachableTime.4883 = 100
ipv6InterfaceRetransmitTime.4883 = 100
ipv6InterfaceForwarding.4883 = 0
ipAddressIfIndex.1.4.10.181.243.109 = 4883
ipAddressPrefix.1.4.10.181.243.109 =
ipAddressPrefixOrigin.4883.1.4.10.181.243.109.24
Aruba-2930M-48G# show oobm ip
  IPv4 Status          : Enabled
  IPv4 Default Gateway : 10.181.243.254
        |                                     Address  Interface
 Member | IP Config IP Address/Prefix Length  Status   Status
 Global | dhcp      10.181.243.109/24                  Up
Version history
Revision #:
1 of 1
Last update:
‎10-04-2018 12:15 PM
Updated by:
