Highlighted
Contributor I
Aruba 3810 Ospf redistribution into bgp of External E2 routes
We are looking to redistribute OSPF routes into BGP which has been successful except for a couple of external E2 OSPF routes, what is the procedure in Aruba OS version 16.05.11,
we have tried to match on a route-map
match route-type external type-2
but this has been unsuccessful our only solution is to use static routes and redistribute those, is there another solution like cisco to match the external?
Dave
Highlighted
Re: Aruba 3810 Ospf redistribution into bgp of External E2 routes
Did you manage to redistribute all routes before configuring the route map?
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
Highlighted
Contributor I
all the routes were redistributed except the external OE2,
then we tried the route map with no luck
then we added the statics and redistributed them
I take it Aruba does not have a command to match these routes like in Cisco?
thanks
Dave
