last person joined: one year ago
Bring performance and reliability to your network with the HPE Aruba Networking Core, Aggregation, and Access layer switches. Discuss the latest features and functionality of HPE Aruba Networking switching devices, and find ways to improve security across your network.
Aruba 3810 Switch - How to Change the BGP Route Selection by Configuring BGP Local Preference
May 29, 2020 12:01 PM
This article discusses how to modify the BGP routing process to use the Local-Preference rule to select only one path.
In the following example, switches Rack2sw1, Rack2sw2 and Rack2sw3 are configured for BGP routing. Rack2sw1 is receiving a valid Nexthop from switches Rack2sw2 and Rack2sw3 for the prefix 10.10.10.10/32 (see output of show ip bgp below).
Rack2sw1# show ip bgp
  Local AS            : 1             Local Router-id  : 1.1.1.1
  BGP Table Version   : 6
  Status codes: * - valid, > - best, i - internal, e - external, s - stale
  Origin codes: i - IGP, e - EGP, ? - incomplete
     Network            Nexthop         Metric     LocalPref  Weight AsPath
*  e  10.10.10.10/32     192.168.12.2    0                     0      2        ?
*>e  10.10.10.10/32     192.168.12.3    0                     0      3        ?
By default the maximum number of equal cost IP load sharing paths is four.
This is the reason for two entries in the routing table for the 10.10.10.10/32 prefix:
Rack2sw1# show ip route
                                IP Route Entries
  Destination        Gateway         VLAN Type      Sub-Type   Metric     Dist.
  10.10.10.10/32     192.168.12.2    1    bgp       external   0          20
  10.10.10.10/32     192.168.12.3    1    bgp       external   0          20
The "ip load-sharing" configuration option can be configured for the values of 2-4. Having only one path for a prefix requires configuring the BGP router for path selection. The following  BGP configuration is an example that  does not include a path selection:
Rack2sw1# show running-config router bgp
Running configuration:
router bgp 1
   enable
   bgp router-id 1.1.1.1
   neighbor 192.168.12.2 remote-as 2
   neighbor 192.168.12.3 remote-as 3
The first three BGP path selection rules follow.
 • Prefer the route with the lowest Administrative Distance.
 • Prefer the route with the larger weight.
 • Prefer the route with the highest LOCAL_PREF value.
The modified switch configuration for path selection;
 • Adds an “IP Prefix-List” which matches the IP address 10.10.10.10.
 • Adds a “Route-Map” which sets the BGP Local-Preference for the neighbor Rack2sw1.
 • The BGP configuration includes the Route-Map .
********** IP Prefix-List to match Rack2sw1 **********
Rack2sw1# show run | begin prefix
ip prefix-list "ten-ten-ten-ten" seq 5 permit 10.10.10.10 255.255.255.255 ge 32 le 32​
Rack2sw1# show ip prefix-list
 ip prefix-list ten-ten-ten-ten: 1 entries
    5            permit 10.10.10.10/32 ge 32 le 32
********** Route-Map to set the BGP local preference **********
Rack2sw1# show running-config | begin route-map "Local-Preference" permit
route-map "Local-Preference" permit seq 10
   match ip address prefix-list "ten-ten-ten-ten"
   set local-preference 110
Rack2sw1# show route-map
 Routemap information
********** Modify the BGP routing process to use the route-map **********
router bgp 1
   enable
   neighbor 192.168.12.2 route-map "Local-Preference" in <==========
********** Restart BGP neighbor **********
Rack2sw1# clear ip bgp neighbor 192.168.12.2
Updated Routing Table Has A Single Entry For 10.10.10.10/32:
Rack2sw1# show ip route bgp
                                IP Route Entries
  10.10.10.10/32     192.168.12.2    1    bgp       external   0          170
Rack2sw1# show ip bgp 10.10.10.10 255.255.255.255
  BGP Table Version   : 89
  Network     : 10.10.10.10/32        Nexthop          : 192.168.12.2
  Peer        : 192.168.12.2          Origin           : incomplete
  Metric      : 0                     Local Pref       :
  Weight      : 0                     Calc. Local Pref : 110
  Valid       : Yes                   Type             : external
  Stale       : No
  Best        : Yes (Higher Local Preference)
  AS-Path     : 2
  Communities :
  Network     : 10.10.10.10/32        Nexthop          : 192.168.12.3
  Peer        : 192.168.12.3          Origin           : incomplete
  Weight      : 0                     Calc. Local Pref : 100
  Stale       : No
  Best        : No
  AS-Path     : 3
  Communities :
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
