Contributor I
Aruba 3810 & 2540 - LACP configuration
I wanted to implement LACP for a client.
I have two core switches aruba 3810 and for distribution switches aruba 2540.
Can you guys help how to configure LACP.
I also wanted to know if there's any software simulator like packet tracer for aruba switches.
Thanks in advance.
Re: Aruba 3810 & 2540 - LACP configuration
For LACP you need to create a trunk:
Command:
trunk 21,22 trk1 lacp
For port 21 and 22
For provision (ArubaOS-switch) there is no simulator, for ArubaOS-CX there is.
Contributor I
So configurations are made only on the core switch.
Lacp needs to be configured on both sides.
As you have 2 ArubaOS-Switch the command is equal to both switches.
Did you configure the core as a stack?
Can you share your overall design? Because only implement LACP is not enough.
Contributor I
Yes it's configured as stack.
Here's a brief setup ( find image)
MVP Guru
Cisco Catalyst style...where are Arubas?
Contributor I
Hi Parnassus,
I was asked for a design, I used packet tracer just to give a quick description.
