Highlighted
MVP Guru
Re: Aruba 8320/8400X fans airflow direction
Your comment has been forwarded to the Product manager.
Highlighted
If a customer has an 8325 B2F model can they just purchase the F2B fans to convert it?
Highlighted
MVP Guru
Yes, but - in addition to F2B Fans - the F2B Power Supplies (JL632A) are
required too.
