Aruba 8320 OS CX NTP sourcing
We have recently installled two Aruba 8320 L3 core switches.
We have configured the devices and they are upgraded to the latest firmware and all is running smoothly .....
I have ran into some issues with setting up the services, is it possible to bind tacacs and ntp server request from a particular ip address within a given vrf?
e.g. Have enabled the ntp server, and binded it to a vrf but no sourcing options?
thanks
Dave
Re: Aruba 8320 OS CX NTP sourcing
its ok i found it :)
MVP Expert
Can you share ? can be help other...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Hi all,
sure you can source it for ntp/tacacs etc
ip source-interface ntp/tacacs x.x.x.x vrf xxxx
 a sneaky find
thanks
Dave
