Highlighted
Aruba 8320 VSX Topology not forward packets
I have two ARUBA 8320 connected with VSX technology as L2 and Checkpoint FW as L3 above them.
When I try pinging to a server connected to 8320 from the 8320 SW I have reachability but from the FW I do not have.
In my last case, the engineer sends me two commands useful from the shell:
ovs-appctl -t hpe-vsxd vsx_filter_dump
ovs-appctl -t ops-switchd  vsx/show_isl
but when I typing dose commands I get access denied
also "sh -" in shell mode with my admin password dosn׳t work
Dose anyone have such a problem or can help?
Thanks!!
Highlighted
MVP Guru
Re: Aruba 8320 VSX Topology not forward packets
Hello Itay and welcome!
I fear that starting a thread about Aruba 8320 VSX into the Airheads's Volunteer Corps - Support Request section could made it less visible than desired; it's better if you move (or ask the Airheads moderator to move) it into the proper Airheads's Wired Intelligent Edge (Campus Switching and Routing) section.
Said that, it looks like "the engineer" (he/she is from Aruba Support?) suggested you to execute two Shell commands (ovs-appctl) ...well...before going that deep (usually networking related issue can be diagnosed and solved without using the ServiceOS Shell but just using the ArubaOS-CX CLI) I suggest you to explain what is your actual Aruba VSX running configuration (do sanitize it by properly obfuscating sensitive information) providing as much information as you can (software version, network topology, interface information) and explain here how you configured your Checkpoint Firewall (acting as the router for your network) and how you connected it to the VSX (acting just as a Layer 2, as you worte) showing relevant VLAN/Interfaces configurations.
Doing so it's highly probable other Airheads community members can give you valuable help.
Highlighted
Hi Parnassus,
Thank you for your response.
There is a Topology diagram attached to the post.
#VSX-Configurations Core-SW1#
vsx
system-mac 00:00:00:01:83:20
inter-switch-link lag 1
inter-switch-link hello-interval 3
inter-switch-link dead-interval 10
inter-switch-link hold-time 2
role primary
keepalive peer 1.1.1.2 source 1.1.1.1 vrf VSX-KEEPALIVE
keepalive dead-interval 10
keepalive hello-interval 3
interface lag 1
description ISL-SW-CORE-2
no shutdown
no routing
vlan trunk native 1 tag
vlan trunk allowed all
lacp mode active
lacp rate fast
interface 1/1/54
no shutdown
lag 1
interface 1/1/53
no shutdown
lag 1
interface lag 10 multi-chassis
description Core-FW-1
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/1
no shutdown
lag 10
interface lag 20 multi-chassis
description Core-FW-2
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/2
no shutdown
lag 20
interface lag 101 multi-chassis
description SW-TOR-1-2
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/47
no shutdown
lag 101
interface 1/1/48
no shutdown
lag 101
#VSX-Configurations Core-SW2#
vsx
role secondary
keepalive peer 1.1.1.1 source 1.1.1.2 vrf VSX-KEEPALIVE
interface lag 1
description ISL-SW-CORE-1
no shutdown
no routing
lacp mode active
lacp rate fast
interface 1/1/54
no shutdown
lag 1
interface 1/1/53
no shutdown
lag 1
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/1
no shutdown
lag 10
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/2
no shutdown
lag 20
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/47
no shutdown
lag 101
interface 1/1/48
no shutdown
lag 101
#VSX-Configurations Core-TOR1#
vsx
role primary
interface lag 1
description ISL-SW-TOR-2
no shutdown
no routing
lacp mode active
lacp rate fast
interface 1/1/54
no shutdown
lag 1
interface 1/1/53
no shutdown
lag 1
description SW-Core
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/1
no shutdown
lag 101
interface 1/1/2
no shutdown
lag 101
interface lag 11 multi-chassis
description A220\C1
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/3
no shutdown
lag 11
#VSX-Configurations Core-TOR2#
vsx
role secondary
interface lag 1
no shutdown
no routing
lacp mode active
lacp rate fast
interface 1/1/54
no shutdown
lag 1
interface 1/1/53
no shutdown
lag 1
description SW-Core
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/1
no shutdown
lag 101
interface 1/1/2
no shutdown
lag 101
description A220\C1
no shutdown
no routing
vlan trunk native 1
lacp mode active
lacp rate fast
interface 1/1/3
no shutdown
lag 11
I have another area in the network that was with the same issue and connected with the same design and products (Aruba 8320&Checkpoint FWs) when "the engineer" came to our office and troubleshoot exactly the same behavior as this issue.
When he got into shell mode and execute a few VSX shell commands and reboot the switch the VSX starting to work and we can ping from the FW (GW) to the servers. after that, he shows us the "show commands" from shell to see the VSX function and working.
the configuration in the regular CLI copied from the working area to the second area that not working properly.
I  looking, someone that can guide me who to see in shell mode the VSX status and if the VSX status not good who to fix it from shell mode because I tried anything and nothing works
Thanks!
Highlighted
MVP Guru
That's strange, I recall your posts were already answered here. Is this a duplicate (was this thread moved from another section?).
