Highlighted
Occasional Contributor I
Aruba 8325 - SNMP VLAN interface stats monitoring
I have an Aruba 8325 switch and would like to monitor the interface traffic with SNMP.
However, I am able to get the traffic stats for the physical interfaces, but the VLAN interfaces do not seem to have their interface speed set and the stats counters are always zero.
For example, the following is returned using SNMPWalk.
F-MIB::ifDescr.16778527 = STRING: vlan1234
IF-MIB::ifType.16778527 = INTEGER: propVirtual(53)
IF-MIB::ifSpeed.16778517 = Gauge32: 0
How can I use SNMP to get interface traffic stats for VLAN interfaces?
Thank you!
Highlighted
MVP Guru Elite
Re: Aruba 8325 - SNMP VLAN interface stats monitoring
What release ?
do you have enable l3 counters ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
The system details are:
Vendor : Aruba
Product Name : JL635A Aruba 8325-48Y8C 48p 25G 8p 100G swch
ArubaOS-CX Version : GL.10.03.0071
Yes, I have added 'l3-counters' to the VLAN interface config but this only seems to add additional L3 counters.
Here is a normal physical interface 'show interface' counters:
Rx
3455219 input packets 305009310 bytes
0 input error 812 dropped
0 CRC/FCS
Tx
3767813 output packets 345485584 bytes
0 input error 0 dropped
0 collision
Here is the VLAN interface (that the physical interface above is using) 'show interface' counters, with 'l3-counters' added:
Rx
       L3:
            58618 packets, 5448573 bytes
 Tx
       L3:
            0 packets, 0 bytes
(I'm not sure why the Tx counters are zero).
I don't know yet how to access those additional 'L3 counters' using SNMP.
Highlighted
MVP Guru Elite
ask the support... or using API for get vlan interface stats ;)
Highlighted
MVP Guru
you'll have access to them through API:
l3-c-api.JPG But still looking how-to for SNMP...
Highlighted
I was hoping/expecting to be able to do this with SNMP as that is what our monitoring system is based on.
I don't remember having this issue when using Cisco L3 switches in the past.
I wanted to avoid having to have to mess about with integrating our monitoring system with the ArubaOS-CX API to just get VLAN interface stats.
I don't know the technical details and reasons, but it seems like an oversight that VLAN interfaces cannot be monitored using SNMP and one has to resort to using the APIs.
Highlighted
MVP Guru
This is a defect and it will be corrected. (intend in 10.4).
Highlighted
That is great to hear!
Do you have an official source for this?
Highlighted
MVP Guru
I'm not sure what is behind your request to ask for an official source ?
For time being, to support you further I invite you to reach your local SE
for appropriate follow-up.
Highlighted
Sorry, I'm new to these forums and I don't know your role/capacity.
We are currently having delays in getting official support for our Aruba switches, so I wanted to use this channel for now.
I just wanted to understand your statement about this issue being fixed and in what version. Is there an official source that verifies/confirms this?
