Highlighted
Contributor I
Aruba 8900 user manual
Dear Aruba Support
Can I have Aruba Core Switch XL.10.03.0030 user manual.
Highlighted
MVP Guru
Re: Aruba 8900 user manual
All the user manual and release notes are on :
https://asp.arubanetworks.com
or here as well (ex 8400):
http://h17007.www1.hpe.com/us/en/networking/library/index.aspx?cat=switches&subcat=8400&type=4+6+7+13#.XV-qrOgzZjG
Most information for 10.3 is there.
If you talk about Release Notes for 10.03.0030, then this should be available when the release is on ASP (shortly).
Highlighted
MVP Guru Elite
You need what ? release note ? or doc
For doc it is available here http://h22208.www2.hpe.com/eginfolib/Aruba/OS-CX_10.03/5200-5942/index.html#book.html it is for 10.03.xxx
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Aruba 8900?.
I think you are referring to Aruba 8400, if so, the information you need is here:
https://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-a00068057en_us-1.pdf
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
